Brief Description: Work on Skyview wiring upgrade and SB 12-11-09
42D-17, 42D-19. Swapped pins 3 and 4 at the Option 37 Pin D-Sub of WH-0026 (12 SV Fin Conv). This is per the Wiring Change for Skyview Version 4.0 firmware update (8/31/2012). It was not easy to fit the Tool because of the small holes. I manage to swap the pins without any damage. Attached the replacement WH-00055 Cable Extension to the TX-Ant. Temporarily connected the WH-00026 to the WH-RV-12 Optional Harness.
SB 12-11-09. Drilled out the rivets from the fuselage sides as part of this service bulletin on the landing gear.
