Brief Description: Worked on the control stick hand grips
Bought bicycle hand grips and drilled 1/4 holes in the top of the plugs for the PTT switches. Unfortunately the PTT switch would not fit from the bottom of the plug. The plugs of the grips I bought have narrow holes in the center of the plug. I tried to widen the holes using progressively larger drill bits, up to 7/16, but I ended up ruining the plugs. The walls of the hole plug were not thick enough to be widened to the size that would accept the PTT switches. I will look for suitable plugs for replacement.
