Brief Description: Work on optional harness, Reed switches and pins
Tightened and repositioned the cushion clamps holding the Reed switches. Disassembled the Fuse Pin Stoppers, cleaned the parts, applied Loctite to the screws and re-installed. Routed the WH-RV-12-Optional Harness from the Panel Base to the tunnel. Cut 2 wires to make the Cockpit Light Power Wire and Ground Wire. Not sure if I will proceed to the next steps to install the Autopilot Disconnect since the F-1202A Instrument Panel to which it will install many not be the same with the Skyview option. Will stop for now and wait for more info from Van's.
