Brief Description: Work on Reed switches and Spar Pins
Worked on the right Reed switch today. I had to enlarge the hole in the arm rest to 1/4 inch and advance the switch through the hole, trim part of the rubber from the cushion clamp, and trim the WD-1217 Tube to make it work, This side was a little easier thant the left. Prepared a WH-B167 Spar Pin interconnect wire and attached one end to the right Reed switch by a butt splice. Passed the wire to the left side via the F-1204Y Wire Conduit and attached the other end to one wire from the left Reed switch. Crimped the other wire from the left switch to the WH-F50 Spar Pin wire.
