Shortened one of the wires from the right Reed switch and installed a ring terminal. Installed both left and right Reed switches via cushion clamps to the F-1248 Arm Rests. Passed one wire from the right and both wires from the left switches through the SB-189 bushings. Stripped the end of the wires and crimped butt splices. Did the continuity check but was not successful. Repositioned the switches but still no joy. Will try again later.
