Stripped the end of the Fuel Pump Power Wire and crimped a spade connector. Also installed a spade connector to the red wire from the Fuel Pump and connected the two wires. Removed the left bolt holding the Fuel Pump. Final-drilled 1/4 the holes of a cushion clamp. Passed the wires through the clamp and bolted it to the Fuel Pump. I had to roll the Fuselage on its left side to make it easier to do the work. I could not find the holes in the F-1204B Aft Bulkhead Sides where snap bushings are supposed to be inserted. I looked at the previous steps and I didn't see that I missed a step. Perhaps, they forgot to pre-drill the holes in the factory. Anyway, I drilled the 2 holes using a right angle attachment with a short drill bit. I installed 3 bushings and I couldn't find the 4th. I will have to order more to complete this step.
