Started work on Section 28, Fuel System. Spent some time figuring out the fittings, counting them and making sure they were correctly identified and labeled. Installed the fluid fittings into the ES 40105 Fuel Pump and then bolted it to the F-1048E Facet Pump Bracket. Drilled a hole in the Fuel Valve handle. Deburred and sanded the F-1259G Fuel Valve Bracket Handle, the F-1259B Fuel Valve Clip and the F-1259A Fuel Valve Bracket. Will prime the pieces tomorrow and then assemble them. Final drilled the VA-104-3 Red Knob per instructions.
