Brief Description: Installed the brass elbows to the master cylinders
Threaded the brass elbows into the ports of the master cylinders. Applied pipe thread sealant to the elbows before threading them. Connected the F-1289B Cross-over Brake Lines to the corresponding elbows. Final drilled to 5/16 the holes in three F-1276C System Blocks and placed them over the studs in the F-1276 Bottom Skin. Cut two pieces of plastic high pressure tubing, each 93+ inches long, to make the F-1289C Main Brake Lines. Will install the fittings tomorrow.
