Brief Description: Riveted Step Angles and Bulkhead
Deburred the F-1202F Bulkhead, F-1236 Angles and F-1251 Brackets. Riveted nutplates to the F-1202F Bulkhead, F-1213 Seat Floors and F-1207B Baggage Bulkhead. Final-drilled #30 the 4 holes in the F-1048F Facet Pump Bracket and the Bottom Skin. Countersunk the nutplate rivet attach holes in the Facet Pump Bracket after the holes were final-drilled to #40. Riveted K1000-04 nutplates to the Facet Pump Bracket. Primed the Step Attach Angles, Bulkead and Nutplate Brackets again before final assembly. They had been scratched during previous steps. Riveted the Step Attach Angles to the Step Ribs and then riveted the F-1202F Bulkhead to the Step Ribs. I then riveted the angles and the Nutplate Brackets to the Bulkhead.
