Brief Description: Match-drilled holes for the Left Step
Received the WD-1233-L Step form Van's a few days ago but did not have time to work on it until tonight. Match-drilled holes in the Steps into the Bulkhead and Step Attach Angles. Remove the Bulkhead and Step Angles from the Fuselage and attached these pieces using AN4-5A bolts. I then match-drilled 2 holes into each bracket.
