Brief Description: Riveted Autopilot Servo Brackets and Angles
Riveted the F-1286A Servo Brackets to the F-1207B Baggage Bulkhead and F-1206G Baggage Ribs. Riveted the F-1286B Servo Angles to the Brackets. Installed snap bushings into the holes in the Bulkhead. Riveted the F-1048F Facet Pump Bracket to the Bottom Skin. I tried to install the systems block studs in the Bottom Skin and it was hard (very tight) to put the nuts close to the head of the screws. I'll try again at another time.
