Trimmed excess material from theV-Stab Tip Fairing. Used a rotary tool with a cutting disc to remove excess material fromt he aft part of the fairing. This worked well except for the burnt smell. Sanded the recessed area with a hand block sander. Filed the aft edge using steel files and then sanded with 80 grit sand paper. The fit of the recessed area is really good.
