This mod is to allow access or to view the Tailcone without removing the fuel tank. Positioned the 2 aluminum angles I cut yesterday on the back of the F-1207F Baggage Bulkhead Corrugation. The shorter angle will be riveted to the top of the small rectangular piece at the right lower corner of the bulkhead that will remain in place when the larger piece is removed. Marked the locations where the holes for the rivets will be drilled. Drilled #40 pilot holes in the angles and the bulkhead. Will final-drill to #30 the holes that will attach the angles to the small piece of the bulkhead. Will final-drill the other holes to about #19 for the K1000-08 nutplate holes and AN526C832R8 screws. I will also drill #40 holes for the rivet attach holes in the angles.
