Riveted nutplates to the F-00045 ADS-B Brackets. Attached the brackets to the AV Com Radio Tray and then installed the SV-ADS-B Receiver. Riveted the F-1016HX Guide Bracket to the F-1270D-L Baggage Bulkhead Channel. Match-drilled holes int the F-1282-L Bottom Left Skin using the F-0020 Antenna Doubler as template. Enlarged the center hole to 9/16 and deburred all the drilled holes.
