Got the parts together and my head around the assembly of the ailerons. These are similar to and smaller than the flaps but more difficult. Firstly, the skins are not pre-drilled and the rivet layout was more complecated. Secondly, I need to incorporate sections of the B modification into the aileron. The left aileron can have an optional role trim tab fitted. I wanted to put this in but there are no parts here for that. So I will order them in from Zenith this week with the wing tip fairings. So you need to merge two different drawings and processes together. I go tthe right aileron layed out. When I get back to it I will check it over again before drilling.
