I added two power ports in the baggage area in case I need power or need to charge something back there. The top port is a standard "cigarette lighter" receptacle, while the bottom port has two USB charging ports, a 1A and 2A port each. You can see the carpet kit installed... tedious but sure looks good and should do a lot to dampen sound.
