So close! I finally made myself get the sanding done... As you may remember the first thing I ever painted was the primer on the fuselage, which I got very wrong, caused the primer to go one which the average texture of a blown ceiling ;-(. After MUCH sanding, especially around the million or so rivets, I finally got the primer coat flat and ready to top coat. I masked off the previously topcoated forward fuselage, and got everything cleaned and dust free. Per Valter's suggestion, I also added a small lip at the rear of the cabin air exhaust vent, as he said rain tends to run under it and drip in the baggage area when parked outside.
What is the mysterious bundle under the plane you ask? It is a belly pod? Why no, its a jet like canopy of course.... more details to come :-)
