Now here's a fun little creature to build! This handy little piece takes the fore and aft movement of the stick, is connect by a push/pull rod and turns it into a back and forth movement of the nose up and nose down elevator control cables which then run through the fuselage and the horizontal stabilizer in control the elevator. The nose down stop or travel limiter in built into the stirrup, the opposite limiter is built into the seat back.
