I've just about got the entire booth sealed. Now I need a way to exhaust the paint overspray and fumes. Since I've decided on using the Stewart System aircraft paint, its low odor, water based, and EPA compliant. I decided to use the side door of my garage as the point of exhaust, pulling what little ordor there may be into our own backyard for dissapation.
I made a frame that slips into the doorway, I'll seal the edges with duct tape when its show time. The cheap box fan has a filter covering it to catch any paint in the air before exiting out side. The upper part of the frame will allow fresh air to enter the garage after passing through a basic "bug guard" filter. After flowing around the paint booth, it will then enter through the large high quality filter on the opposite wall from the exhaust fan. We'll see how it will work. I've left myself room in the doorway frame to add a second fan if needed...
