Brief Description: Working on Horiz and Vert Stab Mounting
The placement of the horizontal stabilizer was verified and then the four mounting holes were drilled and mounting AN4 bolts were installed. To make the vertical stabilizer installation easier the rudder was removed. The vertical stabilizer was placed into position and the mounting holes where drilled up to final size. The front attach horn was clamped in place but not drilled at this time.
