The section of fiberglass added yesterday was cut to final shape. A thin layer of filler was added to clean the appearance. The two bottom cowl hinge halves were countersunk and riveted. Fiberglass was added on the inside of the cowl between the prop hole and the oil cooler air inlet. This piece of fiberlass will provide an attachment point for fasteners. Finally filler was added over the countersunk rivets.
