The left side exhaust had an interference problem with the nose gear. A slice was cut in the joint with a rotary cut-off blade allowing the tube to move to the left about 1 inch. Now I need to find a welder for a permanent fix. Two small pieces for the front air baffles were made from 0.025" aluminum sheet.
