Brief Description: Finished wiring for the Time Being
Completed wiring the panel as much as I'm going to for the time being. Connected the Aux Power port, and wired the EIS Warning light. A hole was drilled in the Glareshield and the GPS antenna cable was run with a grommet in the hole. The new SteinAir air vents were installed in the panel. The panel was reinstalled. Edging material was added to the top lip of the glareshield.
