Brief Description: SB-14-08-29 - Nose Wheel Elastomer Installation
The HF load spreader worked perfectly to pull tail up and compress nose gear elastomers for re-installation. Compression needs to be tested each Condition Inspection and any play taken out with aluminum isolator wasgers U-1002.
Damn Chickens. Never leave the shop open when taking a break. They will come in and shit all over the place. Damn Chickens.
Jacking up tail to push nose down on gear
Black concrete weight used to lift for gear removal
