Barracuda
Date:  6-7-2007
Manual Reference:  Ribs sht 303
Brief Description:  Rib Production
You wouldnt thing that after building a jig and having all the parts precut and finished -that it would still take two hours to set up and epoxy gussets . TIME CONSUMING LITTLE GUSSETS !
The reality is that it is two hours to complete a rough ribs. I actually have some work whip now. One in the jig - gussets apllied and clamped . A second rib out of jig with second set or other side Gussets applied and clamped . And a third completed rib in a clean up situation - remove excess
glue trim gussets . NO SANDING AT THIS POINT i will wait until assembly of spars .
