Barracuda
Barracuda
elevators
dupont epoxy hi fil sanding primer was applied , blocked filled , primed blocked filled and on and on until the surfaces were true for both sides.
Ten both were mounted and checked for deflection requirements and clearances.
Barracuda Home
1856
Ailerons
Center section
138
477
242
529
Hardware
Metal Block 1
Metal Block 1 - open
Metal Block 2
Metal Block 2 open i
Metal Block 3
Tech councilor / ins
wing outer panels
83
272
