Brief Description: Match drill right skin and j-stiffeners (10-7)
I clecoed the bel crank ribs (F-1029) in place, but I didn’t drill them until I flipped the skin over just for ease of access. I place the j-stiffeners in place and clecoed on the right skin. I left out the clecos on either side of the stiffeners until I could get them taped into place, then I added them into help hold everything and keep them lined up. The side skin took a little work to get the corners in, but if you just work from the bottom to the top, then it all fits nicely. I normally remove the blue film ahead of time, but I figured I was just match drilling flat parts so no impact on the fit once the blue film is removed. Again, lots of holes to drill and lots of clecos…might have to order some more when I get to the wings.
Side skin clecoed in place (22-260)
Bell crank ribs clecoed in place (22-261)
Half the holes drilled in the right skin and j-stiffeners (22-262)
