Marks Web Site
Date: 1-22-2022
Number of Hours: 3.00
Manual Reference: 9-7
Brief Description: Final drill elevator skins (9-7)
Now that everything is deburred, its just a matter of final drilling all the skin holes. The manual says to start in the middle and work your way out…and place a cleco at each hole. That’s a lot of clecos, so I had to order some more...another 200 silver clecos. I imagine the wings will take even more…when they get here (coming up on 11 months since order date). Anyway, I final drilled the elevator horns and close outs…now just working my way across the skins. It’s a slow process, pull cleco, dill, replace cleco, mark hole, then repeat, so on and so forth. I’m also drilling the trailing edge as well, 90 degrees to elevator chord line.
Elevator horn clecoed in place and final drilled (22-009)
Close out final drilled (22-011)
Final drilled one of the skins (22-020)
