Brief Description: VS ribs prepared and clecoed to VS spars.
The four vertical stabilizer ribs VS-704, VS-705, VS-706 and VS-707 were next on the list. I edge deburred and then straightened it rib by fluting with my fluting pliers. Next I clecoed the ribs to the front and rear spars VS-702 and VS-803PP. I final drilled the hinges and spar doubler to the rear spar VS-803PP. Then I drilled all the rib to spar attach holes to #30. Next, I clecoed on the skin VS-801PP and match drilled the holes to #40. Thats it for today. Next time I will disassemble the VS and start the deburring and dimpling.
