Brief Description: Dynafocal Engine Mount Installation
Mounted engine mount to firewall using 3/16 " bolts through pre-punched tooling holes. Checked alignment. With mount bolted to firewall I drilled through the engine mount holes through firewall for AN6 bolts. I reamed each hole to final size. As each hole was reamed, I inserted the AN6-24 bolt and lightly tightened with specified hardware. Once all 6 holes were drilled and reamed with bolts inserted, I did the final torque to specification. I will safety the nuts at a later date.
