Brief Description: Static Line Installation to Instrument Panel
The static line runs from the staitic ports to the instrument panel along the left F-718-L upper longeron. Earlier I had made several static line attach clips as shown in static lineattach detail on DWG 25. I marked where I wanted the clips to be installed and drilled out those skin rivets. I also enlarged the hole at the top of the left F-724-L aft fuselage bulkhead to 7/16" as shown in Detail K on DWG25 and inserted a SB437-4 snap bushing. I started at the aft baggage bulkhead and fed the static line through the snap bushing aft to the left static port tee and inserted into the quick connect fitting. I installed 2 static line attach clips. I installed two longer AD426AD3 rivets to secure the static line to the longeron. Later I will install the remaining snap bushings and finish the static line run to the instrument panel.
