MARK'S WEB SITE
Date:  6-22-2015
Number of Hours:  1.50
Manual Reference:  Gretz Bracket Kit
Brief Description:  Garmin GAP 26 Pitot AOA Mast Mount
Earlier in the build I had fit the pitot probe backing plate and mounting mast to the 4th rib inboard from the left wing tip as shown in the Gretz pitot tube mounting bracket kit instructions. Today I final fit the mast and dimpled the mounting holes for AN426AD3 rivets. I also dimpled the four #8 screw holes in the left W-705-L bottom wing skin. Now I am ready to rivet the lower wing skin to the wing structure after a little more prep work. I also checked and applied torque seal to the left wing bellcrank hardware. I went back and secured the roll servo wire harness to the Click-N-Bond pad with the supplied tie wrap.
Pitot Mounting Mast
Pitot Mounting Mast
Left Wing Aileron Bellcrank
Roll Servo Harness Secured
