Brief Description: Installation of TG-10 Heater Vent
The TG-10 heater vent is installed on the engine side of the firewall. I had previously cut the 2" hole and drilled the #12 holes for AN3-4A bolts. I put a thin bead of firewall sealant around the hole. I installed the bolts into the vent and then installed the vent to the firewall while holding the bolts. I reached around and installed the 2 AN960 washers and 2 AN nuts. I cleaned off the excess sealant.
