Brief Description: Backrest Brace and Flap Actuator Covers
I deburred the F-785A backrest brace and fabricated the F-785B attach angle. I fit the attach angle to the floor and marked the hole location. I drilled the holes and deburred. I clecoed the parts together and fit into postion. I test fit the 2 F-760 flap actuator side covers and match drilled the holes. Next I cleaned, primed and painted the parts. Once dry I rivited the angle to the backrest brace and also riveted the K1000-08 nutplates to the backrest brace. I will set these aside until final assembly to allow access the the elevator actuator tunnel.
