I finished the F-767 attach plate by riveting the K1008-08 nutplates and then riveting it to the F-766A flap motor channel. I mounted the F-766 channel to the fusalage and then installed the flap motor with the required hardware as called for in DWG 33. I connected a 12v battery and ran the actuator to the mid position. I bolted the motor to the Wd-613-EF actuator arm and safety wired in place.
