Today my wife Rose helped me dimple the two bottom outboard wing skins. She would hold the skin while I dimpled each hole on my dimpling table. That took one hour and the skins were set aside for priming later. Next I fabricated the two aileron stops A-914 from AA6-125x1x1 aluminum angle. I cut the two pieces to rough width of 17/32" using my band saw and finished the width to 1/2" using my disc sander and 6" scotch brite wheel. I cut the other dimensions as called for in DWG 13A using my pneumatic cutoff wheel. Last I drilled the two #30 holes in each stop, deburred and cleaned up the edges.
