I used my hand squeezer to dimple all the bottom outboard wing skin ribs. I also dimpled the rear wing spar with my hand squeezer and since the material was thicker also touched up the dimples with a light machine countersink. Before I rivet the lower outboard skins on, I will spot prine the rib flanges and the wing skins where the rib flange contacts the skin.
