MARK'S WEB SITE
Date:  1-2-2014
Number of Hours:  5.00
Manual Reference:  Sec 8-15 DWG 38
Brief Description:  Install Lower Wing Platenuts
Earlier with the wings mounted to the fusalage, I had drilled the screw holes in the bottom fusalage skin that is screwed to the bottom of the wing. My next task was to install the 10 K1100-08 platenuts on each wing fuel tank lower rib flange. First I deburred the holes on the fusalge lower skin and then the holes on each wing. The AN509 screw is tappered so I need to countersink both the holes in the fusalage and the holes in the wing. I did this using my pneumatic squeezer. The platenuts are held in place with AN426AD3-3.5 rivets. I shortened one #8 screw and used the dimpled hole to center and the screw to hold the platenut in place while I drilled the #40 holes. Once I had all the rivet holes drilled in both wings, I deburred the holes. I setup my pneumatic squeezer and used the shortened screw to hold the platenuts in place and set all the rivets.
Lower Fusalage Skin Dimpled
Wing Tank Rib Platenuts Drilled
Squeezing Platenut Rivets
