Brief Description: Modify Center Floor for Fuel Pump Assembly
In order for the fuel pump bottom cover F-7115A to fit the floor stiffeners, I would need to shorten the center floor cover the length of the bottom cover. I marked the center floor cover and cut off the excess using my band saw. I fit the cover back to the floor stiffeners and then fit the fuel pump bottom cover in place. I used the same wood spacers to make sure the cover was at the right height and a straight edge check alignment with the center floor cover. I placed the fuel selector cover in place and marked the holes for the screws that will hold the selector cover in place. I drilled and deburred the holes to #40. I will prime and paint the parts on a warmer day.
