I installed forward landing gear brackets and strut attachment bracket. Read the drawing carefully here because it points out that PF-161 is to be 700mm apart and PF-176 outside measurement is 860mm. PF-161 and PF-176 do not have the same inside measurement. I installed aft brackets on bottom of cabin. Changed the hardware to 8- AN4-11A and 4 AN3-11A for the front bracket as the bolts were to long that was specified in the drawings. I use the laser level to make sure the parts were spaced right and in line with as per the drawing. I think the best way would be as Don had suggested making a square pattern and clamping each bracket in a corner. I will use a peace of aluminum angle to align the two PF-170 parts when I do them.
