BushCaddy ELSA
Date:  5-9-2009
Number of Hours:  5.00
Manual Reference:  None
Brief Description:  F/W insulation, Parking brake valve
Installed to 90 deg elbows on parking brake valve and ran 1/8" brake tubing from Master cylinders to parking brake valve. Connected push pull cable and installed in panel. Removed all equipment from F/W and installed heat shield. Peg helped me replace all the removed parts. Assembled the push to talk buttons on the stick grips and soldered wires. Assembled grip tops with push to talk buttons.
F/W insulation
F/W insulation
Push Pull cable attached
