I mounted the left seat belts. Ran wires from intercom to control stick and up control stick. I could not get the wires to just push through the stick so I used the same trick I used on the wings is hooked up the vacuum to one side of the stick and put my thumb over the other side and feed the pull string up through the stick. It worked great.
