BushCaddy ELSA
Date:  5-7-2007
Number of Hours:  3.00
Manual Reference:  Section K
Brief Description:  Started the Right wing
Cleaned shop and set up table for wing construction. Organized parts and set out parts for Right wing. Drilled and clecoed PK-309, PK-319, PK-320, PK-321 to PK-313. PK-319 back edge is set in 40mm. Drilled and clecoed PK-352 and PK-356 to PK-313 at 1300mm on center. Drilled and clecoed PK-325 & PK-327 to PK-313. Set PK-325 at 155 deg and centered the were the bolt hole will be drilled at 2337mm from root end and 25mm down from the edge of PK-313.
