Looked over Wing drawings and read through Don's wing log. Installed Rudder pedals the new bolts have arrived. The drawings call for AN3-20A that go through the UHMW but for some reason my kit had AN3-21A and they were to long with the exception of the two bolts on the center forward UHMW they are AN3-21A. I did not find the 970-3 washers in the kit so I had to order them too. Riveted glare shield with pulled rivets will do the driven rivets when I have an extra hand available. Drilled and counter sunk left door frame and dimpled PF- 208
