Brief Description: First Coat of Primer on the Bottom Right Wing Top
Laid a moving blanket on the top of the work table. Moved the lower right wing to the table with the help of Bill Gill and placed it with the top up. Using the small iron went over the top of the wing and ironed down each of the areas around the rivets and any edges which were not smooth. Washed the top and rinsed it with clear water. Applied one coat of primer with a foam bush one panel at a time around the wing. The second coat will be applied the next work day.
