Brief Description: Primer Painting on the Bottom of the Lower Right W
Applied a second coat of primer to the top of the lower right wing bushed on 90 degrees from the first coat. Turned the wing over so the bottom side is up. Used the small iron to go over the bottom of the wing and smooth down the edges and around each of the stitch rivets. Used the soldering iron to melt out each of the access ports on the bottom of the wing. Washed the bottom of the wing with the soap solution and rinsed with clear water. Using a foam brush applied a coat of primer to the trailing edge half of the wing. The rest of the wing will be painted during the next work day.
