Brief Description: Fitting the Top Cover on the Left Wing Stub
Laid out the section of fabric for the top of the stub to ensure correct sizing and position for installation. Laid down a line of glue alone the side wall about 2 inches wide just above the top of the wing stub. Provided a small cut out around each of the lift cables. Cut the aft end of the fabric along the contour of the trailing edge with a 2 inch offset. Glued the aft angle section of the fabric to the frame and held in place with clips. Added a strip of 2 inch fabric tape along the side wall centered on the edge of the top fabric glued to the side wall. Glued the tape in place and let the glue dry some. Used the small iron to set the tape in place along the side wall. End of day.
