Glued the forward edge of the fabric to the longeron. Started at the trailing edge and pulled the fabric across the bottom of the stub and up the side and clipped it in place. Trimmed the trailing edge of the fabric 1 1/2 inches from the edges of the wing stub. Taped up the exposed edges on the wing stub. Cut out holes for the wing spar mounting points. Applied glue along the top of the outer wing rib and pulled the fabric in place. Glued the front of the bottom fabric to the leading edge of the spar. Applied reinforcing patches for both wing stub attachments, control cable access, and electric plug access. Ironed the fabric at 255 degrees to tighten the fabric across the bottom of the wing stub. Additional ironing may be required. End of Day.
