LARRY'S WEB SITE
Date:  4-17-2019
Number of Hours:  3.50
Brief Description:  Ironed the Left Side Fabric
Cut reinforcement patches for the penetrations of the fabric at the lift points, cable openings, step brace, data plate, horizontal stabilizer brace attachment, and the tail light wire access. Glued each patch in place and let them dry. Trimmed a 4 by 5 inch segment of .024 aluminum sheet and formed it around diagonal F22 next to the vertical F23. Secured the plate in place with a 1/8 inch pop rivet. Ironed the left side fabric at 250 deg to remove the loose material and set the patches. Laid out a section of fabric under the left wing stub and clipped it in place along the inside wing rib. Glued the inside edge along the bottom of the fuselage up to the aft landing gear strut. Left it to dry to be finished during the next work day.
Back Plate for Data Plate
Wing Stub Fabric
Wing Stub Fabric
