Brief Description: Finished Gluing Up the Left Side Fuselage Covering
Applied glue to the top longeron in lengths of about 3 feet. Used clips to hold the fabric over the longeron and continued to coat the fabric with glue. Moved along the top longeron in 3 foot increments gluing the fabric to the longeron. Cutouts completed where necessary to allow the fabric to lay around the longerons. Moved back to the front and trimmed the fabric along the front. Glued the vertical fabric to the fuselage. Now moved along the bottom longeron again trimming and gluing the fabric to the frame. Added a ten inch length of 2 inch tape to the bottom front longeron and glued it in place. I finished the remaining length of the bottom longeron gluing the fabric in place. Trimmed the end of the fabric and glued it to the rudder post. End of day.
